Displays the MPLS contents of the IP routing table for routes with the specified origin.
| bgp | Specifies BGP routes. |
| blackhole | Specifies blackhole routes. |
| bootp | Specifies BOOTP routes. |
| direct | Specifies direct routes. |
| ebgp | Specifies E-BGP routes. |
| ibgp | Specifies I-BGP routes. |
| icmp | Specifies ICMP routes. |
| isis | Specifies IS-IS routes. |
| isis-level-1 | Specifies ISIS Level 1 routing. |
| isis-level-1-external | Specifies ISIS Level 1 External routing. |
| isis-level-2 | Specifies ISIS Level 2 routing. |
| isis-level-2-external | Specifies ISIS Level 2 External routing. |
| mpls | Specifies MPLS routes. This option is available only on platforms that support the MPLS feature pack, which is described in the Switch Engine v33.1.1 Licensing Guide document. |
| evpn | Specifies EVPN routes. |
| signaling-protocol [ldp | rsvp-te | static] | Specifies an MPLS signaling protocol. This option is available only on platforms that support the MPLS feature pack, which is described in the Switch Engine v33.1.1 Licensing Guide document. |
| ospf | Specifies OSPF routes. |
| ospf-extern1 | Specifies OSPF External 1 routing. |
| ospf-extern2 | Specifies OSPF External 2 routing. |
| ospf-inter | Specifies OSPFInter routing. |
| ospf-intra | Specifies OSPFIntra routing. |
| rip | Specifies RIP routes. |
| static | Specifies static routes. |
| unicast | Displays unicast routes with the specified origin. |
| vrname | Specifies a VR or VRF. |
N/A.
None.
The following example displays all the MPLS routes that originate from BGP:
# show iproute mpls origin bgp
This command was first available in ExtremeXOS 12.2.2.
The evpn option was added in ExtremeXOS 30.7.
This command is available on all platforms that support MPLS.
